Weight placement
Jan 27, 2016
7
10
Just a quick question for the pro's there. Working on the scout car and am ready to start adding weight. Car body weighs .68 oz and I have weight pockets routed out behind and in front of the rear axle. Wheelbase is 5" and is set up as a 3 wheel rail runner drilled with 2.5 degree canted rears and positive cant on the DFW. I can get 2 rows of 6 tungsten cubes in each weight pocket. Due to body weight I can only add 22 cubes.
Should I go 10 cubes centered behind the axles and 12 in front or another configuration? We are racing on a 42' Best Track.
Thanks
I would go with 12 behind and 10 in front. You're running on a Best Track, so you can easily afford to be that little bit more aggressive and give yourself that little bit more engine.
