What uv nail dryer is everyone using?
Mar 30, 2014
450
4
Ok I'm about to break down and buy my wife a UV nail dryer! About time right? My question is what wattage and size is everyone using? Fan? Thanks my wife will be so happy!
http://www.pinewoodderbyonline.com/post/uv-lamp-7766394?highlight=uv+light&pid=1290600528
I dont have one either but I remember seeing this. Thinking of getting one also
Your wife.
Riiiiiiight.
http://www.amazon.com/Portable-Manicure-Machine-Perfect-Professional/dp/B00VSRURXY?ie=UTF8&keywords=uv%20nail%20dryer&qid=1461036821&ref_=sr_1_8_a_it&sr=8-8
All the chinese ones are the same. Find a good deal and buy it.
~JBD RACING~ said:
Unless your using legends u don't need a UV light.. Most waxing don't require UV to dry.. Legends is the only one I know of.
I do own a full bottle of legends.... Or should I be using something different?
My understanding was that the UV would speed up the curing process for most waxes, allowing you to cut down on the time required for that phase. Is this not correct?
I contacted the manufacturer for the wax I use, the rep told me that a UV lamp would do nothing to help cure his product. I asked if the warmth from the lamp would help, he said it would only help if I'm trying to cure it in a cold area, it needs to be kept at around room temp or higher to cure. He said it just needs time to cure.
bracketracer said:
...for the wax I use....
And what would that be?
smile
bracketracer said:
The wax is the stuff you put in the wheel bores to add to the go fast!
smile
Hahahaha. Had a feeling the answer would not be immediately forthcoming...
