I think most of us have had trouble with removing the wheels. That's good and bad. A tight fit always means a good toe. I've been using some MA Ford drill bits that give a slightly bigger hole. Both the 2 flute and their 3 flute drill bits are good. The 3 is supposed to give a rounder hole. It's more expensive than the 2 flute drill bit. I'm able to push the axels on by hand with these bits. I got mine from MSC.Directcom.
Good racing.
Good racing.
