Hi All-
This is the first year that my scout has the option of using the other axles than what comes in the box. From reading the post from this site, we will use the revell axles (nails) instead of the crimped BSA ones.
The rules specify that we must use graphite so that is our plan.
In the past we have not grooved the axles other than a small notch under the ales head. When using graphite and the revell axles, is there much speed gain if we add a groove the axles?
Since we will be using the stock BSA wheels that have the two steps in the outer hub, will tapering the axle head make much of a difference?
Note that the BSA wheels can be lightly sanded. We went through a couple of tubes to find wheels with the lowest run out.
Since the revell nails are relatively clean should we start with 1000 grit and work on up and finish with DD4H CK polish?
When cleaning the wheels before polishing do you recommend windex to clean any grit off?
We can run with canted rears so that is what we will do. Unfortunately we need to use the slots so we plan on using epoxy to fill and then drill using the SB Pro to drill the rears.
We have not drilled a car to race with the SB Pro. Do you recommend using a hand drill or a large Pin vise for drilling with the SB Pro? Also, since the axles are smaller than what the pros race with, should we use a #44 drill bit or #43?
I am concerned that the #43 will have extra play once drilled and that the #44 will have too much room in the jig so the holes would be off. What are your thoughts?
Thanks in advance. This is a great site and have learned a lot!
