Hi friends! I’m new to this forum, and am excited to hear opinions, and suggestions from anyone willing to offer their input.
My son just recently had his Pack Derby where he was the second fastest overall by a very slim margin. The Council Derby is coming up in a couple weeks, so we’re trying to tweak a couple things to see if we can improve on the speed a little bit before the next race.
We have an old wooden track in the basement we’ve been using for testing. His car is averaging around 2.38 seconds on that track after 108 races (36 in each of 3 lanes).
We recently purchased some “Graphite-Coated PRO Super Speed Grooved Axles” to try out on his car. Previously we had just been using the axles that came in the kit (removed the burs, sanded…etc.). We put the new axles on, added a little extra graphite powder, and started testing again. To our surprise, the car was slower. MUCH slower. Average times increased to around 2.45 to 2.49.
The car did have a slight pull to the left with the box axles, and also with the new “Graphite-Coated PRO Super Speed Grooved Axles”. Because these new axles are perfectly straight, and the drilled hole is also straight, turning the axle to tune the alignment didn’t make much difference.
We then put one of the box axles that wasn't perfectly straight back on the front to tune the alignment slightly, and the times went back down a bit, but now we’re averaging around 2.41, which is still a bit higher than when we were using all 4 box axles.
I contacted the company we purchased the “Graphite-Coated PRO Super Speed Grooved Axles” from, and they informed us that the axles were a slightly larger diameter than the standard BSA axles to reduce wobble. They suggested that we may need to break the axles in because of that. We did dozens of races with the new axles, which I would think is probably more “breaking-in” than most people do that don’t have access to a practice track, but still can’t get the times back to what we were running with the standard BSA axles.
I do have a treadmill we could try, although I’ve seen many posts from people saying “Do NOT use a treadmill!” Which leads me to another question. Why shouldn’t we use a treadmill? And again, after dozens of races, should we even need to use a treadmill?
I’m hoping someone here has experienced similar results with “Graphite-Coated PRO Super Speed Grooved Axles”, and might possibly have some tricks and tips for using them. Any other suggestions for squeezing out a little extra speed on his car would be very much appreciated.
Thank you!!!
Thank you!!!
