GravityX said:
An axle indexed at the 12 or 6 o'clock position with 1° or 7° will create no steer. It's not until the axle is turned out of this position, toeing the wheel, will steer be created. Hope that makes sense. But to answer your question, I haven't ran any tests to determine what you are asking as it pertains to toe-in or toe-out.
It's probably obvious, but the more degree of bend, the more steer can be generated at the 3 / 9 o'clock position. I would also say that I have found it a bit harder to "dial in" a car with excessive bend in the axle (e.g. more than 5 degress or so); although I am faster with more than the typical 2.5 degree bend I have always heard about.
