Any one used 92 axles for rear only, then used a zinc or easier to bend axle for fdw and raised wheel?
This would be for graphite cars. would be too much speed loss?
I've never done that. The process for polishing and bending the axle isn't really any different. I would just use the 92's all around. All you're going to need to do is work it a little harder to bend it, maybe 10 seconds extra time.
Thanks, I have never bent those axles and those zinc axles bent easily. Just wondered if the
bigger axles helped on the front, I know they would help on the loaded back.
