I have an air guide catching the DFW when I push the wheel in on the bent axle. The only way the wheel spins free if I set the wheel gap wider. It seems to steer without a wobble with a wider gap. Would you suggest sanding the outside of the guide to try and get a closer gap? Or, is it fine running a wide gap?
