I am helping build an Awana car and need some advise. How much weight should the front dominant wheel carry? The car will be ran on an aluminum track, however I don't know the brand or length of the track.
The wheel base on Awana's is shorter than BSA (3-13/16 inches), and the front and back of the block are approximately the same length. The blocks were drilled with "The Block" to 2.5 degree canted rear, and will have a bent dominant front axle to rail ride or rail hug.. The car will have out of the kit wheels and axles modified to the best of my ability with simple shop tools. I will be using John's oil process for wheel prep.
Thanks,
MWD
Thanks,
MWD
