Axle drill size??
Jan 4, 2014
230
Anybody know what size drill bit I should use for the Revell axles? I have several scout cars I need to drill Strict rules so I am going to use the Revell axles instead the dreaded nails in the kit.
Use #44 for Revell
Reactions: nti3nmol
Crash Enburn said:
mxquad said:
#44 drill bit for BSA size axles which I think are .089
#43 drill bit for race axles
Also use the #43 for AWANA axles (just FYI).
I had to go even bigger for AWANA axles...like 3/32" with BSA pine blocks.
If you only have #43- no problem- I did many China axles ( over 20 cars) and then showed Cubs the drop of water and poke a toothpick to move it down the hole and they all came out nice and snug. Raced and no problems.
