BSA building tips
Nov 25, 2011
286
Derby time is aproaching so here are some tips. Hopefully others will pitch in with their favorite tips.
READ and understand the rules of the race.
Ask the race officials if you have questions... (Get answers in writting if possible)
Determine the following:
Can I:
Drill holes or do I need to use slots (Holes are better)
If I can drill holes can I extend the wheel base (Extended faster)
Can I use any axles or only BSA axles (Most races will require BSA axles)
Can I taper the heads of the axles.
Can I cone the hubs of the wheels.
Can I raise a front wheel (3 wheels touching) recomended
ADVANCED QUESTIONS:
Can I cant rear wheels?
Can I railride.
Maybe too advanced. Just ask if it is allowed. You can make a fast car without these.... However faster car if you can do them...
TIPS:
Alignment is key to winning.
If you can drill axle holes. Drill them perfect. This is the foundation of the car. and the foundation of your alignment.
The Block allows you to drill perfect holes...
If you can extend the wheel base do so...
Rear axle back as far as possible 5/8". Front axle 7/8" back to protect against rough BSA stop sections.
If you can not extend the wheel base can you chop the rear 3/8" of the block off and glue to the front? Ask the race folks...
Folks sweat over COM...
Not as important as alignment. If this is your first car start at 3/4"
Build a test car to get the COM correct. Weight should be all in one place near the rear axle...
Most people make the mistake of chasing a certain COM and adding weight all over the car. Dont do this...
Once you get a working design prototype car with correct COM. Start making the real car...
If money allows use Tungsten Disc or tungsten cubes.
Place the weight near or around the rear axle.
FOR BSA races be careful to not cut the axles on your car unless the race officials allow it. Even then keep the tips of the axles as proof.
Allow 3 weeks to build car if possible.
Father / son takes more time to mesh schedules. Paint two weeks before race if possible...
Skip paint on bottom of car to save time...
Prep an extra wheel and axle or two for a crash on race day...
Use zero gravity graphite or oil if you can. Get the Oil DVD from derby dad
Polish axles
Paint tip:
Allow time between coats - best one day
Clear coat - Accrilic is best - Hobby Lobby. Home Depot is worst, takes too long to dry.
In either case, after the color coat, spray clear from at least a 3 foot distance, and very lightly. I do this three times, and sand with 1500 grit between. This seals the color coat underneath.
Once sealed, put several more coats of clear and sand with 1500 to 2000 in between. 1500 is available at Ace Hdwr. 2000 and above from John or similar locations, or from internet.
Paste decals or letters prior to last 3 coats.
Hahaha...
Crash, I was thinking basically the same thing, but not with the Dynamic Duo reference.
By the way... I love the "Man Glitter" comment at the bottom of your posts... LOL hilarious.
Mojo Racing said:
Hahaha...
I did a search for "Zombie Thread" and that pic came up. I liked it. /images/boards/smilies/smile.gif
/images/boards/smilies/thumb.gif
