- Nov 24, 2011
- 3,903
- 30
- 48
- 13
bracketracer said:Assuming that the wheels and axles didn't get damaged, everything you listed could be recycled into a new body, if there was a problem with the old body. The reality is that often new builders will damage wheels or axles while learning how to prep them, especially if they're working alone. It's hard to go fast on damaged wheels or over polished axles. A drill job is easilly checked, prep is an art as far as I'm concerned. So to me it seems like a valid suggestion to replace wheels or axles when someone is struggling and can't find the speed.Chump Change Racing said:That's easy to say when you are already PRO to do away with the am class. I say this because the only real test for my cars is once a month on the league track. You top pros must have some awesome sauce and unicorn milk. Then when someone post about there cars are slowing down first response is buy new wheels and axels. Build a new car so you spend $100 bucks with wheel s,axels,weight ext. send it in and it's an epic failure!!! Then what,,where do you go from there? What I'm saying is I take my racing verySERIOUS!!!!!!!!! and my hats off to you pros you guys are a level above. I vote keep the AM class,,,I now the track is faster and now I'm lost as last years Easter egg on what to do to make my cars faster.... I checked my times from before the track got faster and my times are slower if you use .02 as the mark for the speed increase. Just my 2 cents!!!!!
The only reason I would suggest going with new is because that's what I have done, it's how I figured what worked for me. I had it handed to me many times, and still get it handed to me. Check my SS placings over the last year. You don't have to be a new guy to wreck wheels, I did it just this month. When I really got serious I used a new set of wheels on every car each month. It only took about 4 months or so before I slowed down on how often I got new wheels. That's what I did and it worked, so that's what I suggest. For me a new set of wheels are almost always faster.
