I use the Block and use the process you documented in the video, however, it would seem to me that it is dependent on having a square drill press. Perhaps I am doing something wrong.DerbyDad4Hire said:ET is right on. If you are using the Block then no you do not need a perfectly square table if you use it right. If you need help using the Block just let me know.
I don't want a kittie walker <lol>. I'll square my tableDNA RACING said:you are correct, but the angles of toe in and toe out will be identical, so the result will be a car that "kittie walks" but tracks true. the rear will be off of center slightly but only by a few thousandths and will not affect the tracking on the car as a whole.
5js said:I don't want a kittie walker <lol>. I'll square my tableDNA RACING said:you are correct, but the angles of toe in and toe out will be identical, so the result will be a car that "kittie walks" but tracks true. the rear will be off of center slightly but only by a few thousandths and will not affect the tracking on the car as a whole.
