How far off bottom of car to drill axle holes
Feb 24, 2014
21
I believe you want the axle hole drilled so the front of the car isn't higher then the rear. With a thin car it seems very hard to drill the front axle hole high enough to accomplish this especially once the DFW axle is bent. Looking for any insight. Thanks
Being slightly lower in front may help aero slightly but remember it also effects the rear alignment (if drilled for canted axles). The amount of bend of the dfw axle plays a role in the drill heights. As long as not an excessive amount of bend it isn't that hard to get it really close to right. Keep in mind that for every degree of incline or decline (fdw bend in our world) a line will change from level 0.017" for every inch traveled.
Sorry I didn't tell you exactly what to do. But there are many ways to skin the cat. With the info given you should be able to figure it out no matter how much bend u use.
