I liked the way the "floss fix" made the axle tight, but still easy to break loose to remove and re-prep, and so I went to a bit of an extreme that probably costs some speed, but allows a Cub to mess with the wheels much easier. I drill a slightly larger hole to begin with [ 2.30 mm metric]. I drill it ( or the Cub drills it) way past what is needed so that the axle holes meet up and you can see through the car. This is done with the block, both canted and straight.If one wheel is raised, add a plain vanilla hole to that side above where using floss.
I then thread a few loops of Teflon coated floss all the way through and tie tight across the bottom of the car. Now you have a nice snug fit that is tight enough to take jumping off the track without the tuned axle getting moved, but easy to remove the axle later. It also puts a nice smooth Teflon spot for the DFW to ride on right under the axle hole. Buy threading through and pulling, it is nice and straight and So now it is NOT at a single tangent point, but is the ultimate magic parallel line touching the length of the axle and pushing uniformly against the side. Cars made this way can have the wheels swapped out with all kinds of experiments quick and easy for the Cubs to see on the same car what a "process" change can do.
