Gents
I have one more question before tue big race on Saturday. The rear axles on my son's car slides in a little to easy and I have some concerns that it could potentially slide out during a race. The rear axle were drilled with a cant using the Jewkes block.
Someone said I could put a little dab of super glue on the pointed end of the axle and then scruff it up with sand paper. However, I'm a little nervous using super glue because the vapors can potentially cheap up onto the axle instead of just the tip. I was wondering if you might know of some other method to make the axles stick a bit better?
Thanks
Thanks
