Pledge on axles
jrbryant68 said:
I have gone through the steps of polishing the axles down to 3000 grit polishing paper and I was planning on using a molly boron to coat the axles. As I understand the rules for the race the only stipulation on, lube is no oil or wet lube. So would pledge be something I could use with that as I assume it would be dry before the race. And the second thought going through my head is can I use something like a thin teflon/plastic cutout to line the body around the edge of the axle to reduce friction or would that have any effect? I appreciate the help
Pledge on the axles is perfectly legal. You're spraying it on wet, but then it dries and you whipe it down like you would a table or any other surface.
+1. We use liquid wax and let it dry and wipe/buff off
I sprayed mine, wiped them off, stuck them upright in styrofoam, came back a couple hours later and installed. I don't think you have to wait to terribly long, if at all.
I let mine dry a little while before whipping them off. Not sure if there's an advantage one way or the other. I had time so I waited.
Okay thanks.
By the way, in the past I would prep the graphite by putting it inside the bore then spin the wheel a few time then continually repeat for about 10 minutes for each wheel. My thought was that I was embedding the graphite inside the bore thus giving me longer graphite life. It seems to work pretty well. I usually take 1st in the parents category. What are your thoughts?
That's called burnishing and it is a good way to work the graphite into the bore rather than do run after run after run with adding graphite inbetween each run. It's a way us cheap dad's burnish since we dont have tracks. I use the smooth side of a drill bit that I polished (thanks 5kidsracing AGAIN!), insert it in the bore with graphite and roll the wheel while applying light pressure on the drill bit.
Interesting as I have been looking for this for JR as well .. and here it is ...
hmmm
idea
Come on Mail show up sooner than later ...LOL...
Papa V
HI HAVE QUESTION REGARDING PLEDGE IS IT A ONE TIME SPRAY OR DO U NEED TO RESPRAY AGAIN AFTER EACH RACING EVENT AFTER U WIPED GRAPHITE OFF AXLES AND WHEN U BURNISH THE WHEEL BORE DO U HAVE TO REBURNISH AGAIN OR PUFF GRAPHITE IN AND SPIN AND RUN
I used the pledge once and just added more graphite.
I re-pledged, but didn't see any gain or loss. I whipped it down with alcohol, sprayed, let dry and whipped off. I reburnish before next race one b.c I don't know how much of my original burnish has worn off
thanks for the reply obsessedderby dad so when u say reburnish just means add more graphite in and use what u used to burnish the 2 step process in wheels or do u do that over again i know the car is fast now im just looking at it having the fastests times at district on the 3 lanes
I re-pledge and burnish in more graphite before each event. We have a pack race, a city wide race and then a race that took the place of an "official district " race.
what size drill bit are you using?
Anything smaller than the axle bore, a 3/32" bit would do, as it measures in at .09375" You could go smaller if you'd like, but I wouldn't go much larger.
I use the #44 bit you can buy from John or like GX said. As far as reprep goes, I don't reburnish. I burnish once. After that I clean the axles off with alcohol, repledge, and then add some graphite and spin the wheel. Just make sure you retune if you reprep
