In lieu of the more expensive files for this tool I use this Buck Bros. Jr. Hacksaw from Home Depot. Blade fits between the posts with no issue and it's less than $5. A pack of extra blades are less than $3
Crewzin said:I also have the brownels tool but just started using it. I use the small mini hacksaw blades to make the slot and it woks great, I use them by hand. I slotted my rear axles the other night and it worked well, as I usually do I push my rear axles in to far, so by appyling a little pressure so the wheel and turning the axle with a small screwdriver it comes out very easily. No more warping or breaking a wheel
birddog said:Skippy-
Can you let me know where you found your 0.6 file? I'm looking for one that will work well with the brownells fixture.
thanks,
birddog
Owens Racing said:I would try to go the hobby saw route. The only place I've ever found the slotting files is Brownells and Midway, and they are not cheap. They're pretty much a necessity for gun screws, but IMO overkill for this.
