Tunning graphite car on track?
Pack76oldtown
Pinewood Ninja
Dec 16, 2018
48
5
51
Usa
Is tunning on a track the best method for a graphite car? This might be a dumb question, but I was wondering if Running it down the track would wear through all the wheel and axel prep. I know I can keep packing with graphite, but wont the bore polish and wax benefits disappear by tuning on a track? Just trying to figure What is the best way to gain speed. Lube or tunning?....or other.
Reactions: Deckard
Ummmm not all that awesome withe the G but I am thinking that if you have a track available to tune on......that will always beat out not tuning.
Definitely not saying no tunning. I use a board and quick square as well. Just curious, because oil benefits from multiple runs and graphite doesn’t.
Graphite definitely benefits from multiple runs. My times with graphite cars are consistently best around runs 6-8. For our Pack races, my kids test only once or twice on the track, make it through the den with slightly slower times, and then they get their best times in the finals.
Fundamentally speaking oil process properly applied will run faster than graphite consistently much longer. Graphite techniques properly utilized will run quick with slowing taking place after multiple runs on a track, upwards of 6 to 10 heats before dramatic reductions of speed occur.
Rolling repeatedly on the gentle slope of a tuning board of a max length of 8' should allow you approximately 30 "tunes" before running out of a properly installed and prepped graphite car. In my opinion checking steer on a tuning board is mainly useful to set a base steer to safely Start the tuning process on a track...in order to test run from the base steering adjustment and view the cars performance in various areas such as hole shot, transition, and flat through finish making adjustments in order to maximize speed...for a RACe. Lightening boys techniques are use to verify drill and wheel migration. Both Very important for a frames build out and verification in order to not waste time on a poorly drilled frame. My view is that you are relieing on two basic build out principles to conclude you are "tuning" your cars which in fact you are just checking frame dynamics and establishing a base steer to not jump track. Please dont misunderstand me. If that is all you have available to build and race, we do with what we have, so RACe. Dont be afraid to verify, verify, verify and then add some more graphite. Tap. Begin again. Dont forget to add some graphite before, Tap, check-in......Good luck and hopefully we will see you on the hill soon.
I’ve seen lightning boys videos. I don’t like to order items online. Where would i find pin gages and machinest tools?
Look up Grainger stores near you, I don't know of any other brick and mortar store I can walk into and ask for machine tooling and pin gauges.
Woodcraft and Rockler have a couple of things, not sure about the pin gauges.
Thanks. Portland ME is the closest Grainger and that is about 2 hours away.
Try Amazon ... I have gotten them there.
