resullivan said:I know this is a few months old, but do the people that use monokote use it as a veneer or use it as a cover? Last year we used a veneer and put the monokote on top of the veneer, but I was thinking about just using the monokote.
I used the Monokote trim sheet (the thin decal-type material) over a wood body and I used the Ultracote (the stuff you have to apply with an iron and shrink) to cover cavities in a body. Both worked well. I like the trim sheet because I can use it instead of paint so there's no fumes in the shop when it's too cold outside to paint. That iron-on stuff has a bit of a learning curve to get it on. I ended up applying it with a clothes iron but I had to put a thin towel between the iron and the Ultracote to get it to stick without melting. Then I shrunk it with a heat gun. Took three tries the first time I used it to get it somewhat smooth. I was using the Ultracote lite so the regular Ultracote may be easier.
