TWarwick07 said:Next question, I will need to pick up a drill bit, what size do I get to fit the maximum velocity speed axles
Cubscout Dad said:True, I hear you guys, Just saying for that scout dad like myself that may not have a drill press or fancy tools you can still have a fast car with bent rears. My first year in scouts last year I ran 2 scout cars with bent axles not knowing how to align the rears at the time or polish and wax bores. And still did pretty good at pack and took 2nd and 6th at districts. Just saying /images/boards/smilies/smile.gif
Kinser Racing said:As a scout dad, your experience in tuning a car is very limited. Tuning is a difficulty for most. I'm willing to bet you'd have done better with straight axles inserted in the slots at a cant. It's a tuning thing! While it is possible to do your odds are drastically diminished. I wouldn't even attempt to tune bent rear axles and I am very familiar with tuning.
TWarwick07 said:Kinser , thanks for the advice. I went and picked up the tool to drill the axle holes and have straight axles coming with the wheels on tuesday.
I have a question about drilling the holes:
If you look at the side profile of the car you can see the back of the rear spoiler is where the end of the block was but the bottom of the car is not as long.
I got out a tape measure to check the 5/8 th in. suggested mark for the axle hole and i found something interesting. If i measure 5/8 from the edge of the bottom of the car it lines up right at the axle slot. if i measure 5/8 from the back of the spoiler it is slightly behind the axle slot. which measurement should i use and should i adjust the front axles to maintain the standard wheelbase ??
also notice the chip off the bottom of the car behind the axle slot, will that affect anything when redrilling the axle holes ?
At this point, your car is shaped and ready, just reuse the original holes.TWarwick07 said:I have a question about drilling the holes
Crash Enburn said:At this point, your car is shaped and ready, just reuse the original holes.
The reason for moving the wheels to the very back is to allow for weight placement as far back as possible, without causing the car to do wheelies. Since your car is built up already, that ship has sailed. Just make sure your wheels and axles are prepped and lubed and you'll be fine.
