G
Guest
Guest
Street Rod with a snap in ladder style body and offset weight disc to be drilled after I seal the wood, 1/64" birch for the under carriage.
2 Street Stocks- primered one was inspired by 5k, floater wheel is an old CMI off my first scout car back in '85 reduced to 2 grams, has a very low profile. The hollowed out cavity has vibration dampening foam made to go under RC car fuel tanks. The SS on the right is a rebuild with my first attempt at fenders(balsa) and has a slightly offset weight disc as well.
And finally a 5k inspired street pro I modded, those two strips of birch between the rear axle housing and CA glue around and in the cavity reduce any flex.
Most likely they'll be all show and no go but I'm having a blast anyways!
