speed bump said:Let u know in the morning. Just drill one for testing. Finished my car for the April race.
laserman said:Hi ODD,
I think that if a flat axle will not want to migrate, but a 3* axle will want to migrate, then at a 6 degree angle it will want to jump out there quicker.
The body should probably be angled to match the angle of the inner bore at 90* so that the gap can be the same at any angle. (I think)
The only reason that I can think of that this is not talked about more often here is:
One would need a pin slightly smaller than 3/16" diameter under the Silver Bullet in order to achieve it.
I think 3/16" comes out to about 6.5* so I am going to look for a long pin that is a tad smaller.
Probably the fellas with bigger set ups do it all the time.
bracketracer said:laserman said:Hi ODD,
I wouldn't make the body side 90º to the bore, make it a little less to minimise the contact area if it rubs.
You're right Joe. I don't like when the rears rub the rail at all but that's not why I try different cants.
6º might be a little too far SB, but my two fastest SS cars so far are both "not three degrees".
laserman said:I am a very simple creature that has difficulty imagining beyond the realm of a static builder, so I only have one guess at this time. Given more time I am sure I can come up with others.
ngyoung said:After a certain point having the wheel that canted it will lose forward speed because the wheel wants to travel in an arc in the direction it is leaning. Take a coin and roll it on a flat surface. It will roll in a straight line but once it starts to tilt the path of least resistance sends the coin traveling in a curve. Having that on top of the increased pressure the outside of the bore to the top of the axle and the inside edge of the bore to the bottom of the axle increases with the angle as the axle holds the wheel from going in the direction it wants to roll.
bracketracer said:ngyoung said:After a certain point having the wheel that canted it will lose forward speed because the wheel wants to travel in an arc in the direction it is leaning. Take a coin and roll it on a flat surface. It will roll in a straight line but once it starts to tilt the path of least resistance sends the coin traveling in a curve. Having that on top of the increased pressure the outside of the bore to the top of the axle and the inside edge of the bore to the bottom of the axle increases with the angle as the axle holds the wheel from going in the direction it wants to roll.
But the coin in your example goes straight until it slows below a certain speed. What if that certain speed as it applies to a PWD car is after the finish line?
Some of us are assuming that 3º applies enough pressure between the outer hub of the wheel and the axle head to stabilize the back of the car optimally without producing too much friction.
Have you ever ran a car with 1-1.5º of rear cant? On a bad run you can see and hear the rear of the body banging back and forth between the wheels. More cant would lessen the likelihood of that happening. I'm just saying that 3º may not be enough cant for your setup.
Kinser Racing said:I'd love to see you prove it. I'm not being sarcastic or anything either, I really would love to see it. /images/boards/smilies/thumb.gif
