While researching Balsa, I hit conflicting info about what body style works best.
I've seen cars cut out,(Not Balsa) and made to flex, to reduce vibration.(Usually by back and forth cuts through the wood) But, most info on here about Balsa, is using CA Glue to stiffen it. Why dampen the flex? Does Balsa just get so twisted, it needs the glue?
The X Car types, and other "Experimental" bodies that remove as much wood as possible, use a film or cover to stiffen. Why kill the flex?
I can't imagine the film adds any aerodynamic value, when the body is already void of most of the wood. Why use Balsa, when you have to add weight to stiffen it?
