I briefly revisited the issue I have with the rear right wheel always migrating inward. After drilling a new block and having the same exact problem yet again, I decided to switch things up. I think I solved it, but more testing is needed to be sure. I usually have the fence mounted close to me on the front edge of my drill press table, which means I have to pull the SB and car toward me when drilling. Taking a cue from 5kids video, I moved the fence to the back of the table, so that I have to push the SB into it. This is better in two ways. One, it is easier for me to keep it steady. Two, and probably the culprit in this whole saga, is that when the drilling happens on the outer edge of the table, there is flex, and the table moves slightly down. Conversely, when the drilling is done at the back of the table and close to the drill press post, there is not any noticeable flex. My press is an old Craftsman radial, so it hangs out quite a bit away from the post. After I dialed it in as close to the post as possible, I found that I got perfect axle alignment, at least the one time I tried. Can't wait to drill some more blocks and see. Bottom line- check your table and see if it is deflecting under your weight!
